Brief Description: Installing Rudder- and Nosewheelsteering Cables
Aligned and routed the cable (1/8 galvanized 7x19) from cockpit as mentioned Yesterday all the way to the rudder. Lots of trying and testing.........time consuming!! Now at least, the cable is routed nicely without touching any of the holes and with the correct angles to the rear. Not much to show here! Also installed a tube through the main spar as a guard against shearing. Next will be final installation with swaging (Nicopress) the copper sleeves.
